investor_
investor_ » Вт авг 18, 2020 1:44 pm
sbury писал(а): ↑Вт авг 18, 2020 1:43 pm
ошибки я больше не вижу
2020-08-18 11:16:02 Error loading lookup module mysql.so: NULL
покажите вывод
ldconfig -p | grep mariadb
libmysqlclient.so.18 (libc6,x86-64) => /usr/lib64/mysql_mariadb/libmysqlclient.so.18
libmariadbd.so.19 (libc6,x86-64) => /usr/lib64/mysql/libmariadbd.so.19
libmariadbd.so (libc6,x86-64) => /usr/lib64/mysql/libmariadbd.so
libmariadb.so.3 (libc6,x86-64) => /usr/lib64/mysql/libmariadb.so.3
sbury » Вт авг 18, 2020 1:49 pm
все правильно. покажите ошибку в логе. В том что вы сбросили выше больше не видно ошибок.
investor_
investor_ » Вт авг 18, 2020 1:58 pm
sbury писал(а): ↑Вт авг 18, 2020 1:49 pm
2020-08-18 15:51:53 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 435 Unable to authenticate at present: authentication socket read error or premature eof
2020-08-18 15:54:53 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 435 Unable to authenticate at present: authentication socket read error or premature eof
2020-08-18 15:58:14 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=img1@vm-centos-7.0)
2020-08-18 16:04:56 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=fs@vm-centos-7.0)
2020-08-18 16:08:18 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=th@vm-centos-7.0)
2020-08-18 16:11:40 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=css@vm-centos-7.0)
2020-08-18 16:15:02 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=club@vm-centos-7.0)
2020-08-18 16:18:24 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=tw@vm-centos-7.0)
2020-08-18 16:21:45 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=stg@vm-centos-7.0)
2020-08-18 16:25:07 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=sc@vm-centos-7.0)
2020-08-18 16:28:29 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=gateway@vm-centos-7.0)
2020-08-18 16:31:50 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=whm@vm-centos-7.0)
2020-08-18 16:35:12 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=_spf@vm-centos-7.0)
2020-08-18 16:38:34 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=enterprise@vm-centos-7.0)
2020-08-18 16:41:56 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=webconf@vm-centos-7.0)
2020-08-18 16:45:18 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=ugc@vm-centos-7.0)
2020-08-18 16:48:40 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=surveys@vm-centos-7.0)
2020-08-18 16:52:01 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=learn@vm-centos-7.0)
2020-08-18 16:55:23 auth_login authenticator failed for (User) [212.70.149.4] I=[109.120.170.85]:25: 535 Incorrect authentication data (set_id=se@vm-centos-7.0)
investor_
investor_ » Вт авг 18, 2020 11:49 pm
Ошибка, из названия темы, пропала, но с сайтов письма не отправляются.
С самого сервера уходят с помощью этой команды:
$ echo "test mail." | mail -s Test mailbox@gmail.com
Приходят от "имяюзера@localhost"
Когда отправляю письмо с сайта:
Куда копать?
sbury » Ср авг 19, 2020 7:17 am
вы как то можете больше сказать, чем и как отправляете из своих сайтов.
investor_
investor_ » Ср авг 19, 2020 7:33 am
sbury писал(а): ↑Ср авг 19, 2020 7:17 am
Да, извините.
Отправляю с помощью PHPs mail() через плагин Mailster CMS Wordpress
alenka » Вт сен 01, 2020 10:16 am
Пропишите qualify_domain в конфиге exim, в данный момент у вас localhost
