[решено] Nginx + php-fpm: IP сервера открывает Fedora Test Page
Добавлено: Ср янв 29, 2020 12:11 pm
Панель управления сервером
https://mail.support.brainycp.ru/
server {
listen 80;
listen [::]:80;
server_name default ;
root /var/www/html;
access_log /etc/nginx/vhost_logs/!!default_access;
error_log /etc/nginx/vhost_logs/!!default_error;
location ~ /.well-known { allow all; }
# location ~* robots.txt { root /etc/nginx; }
location ~ /\.ht {
deny all;
access_log off;
log_not_found off;
location / {
root /var/www/html;
if (!-e $request_filename) {
rewrite ^(.+)$ /index.php?q=$1 last;
# error_page 404 /404.html;
# location = /40x.html {
# error_page 500 502 503 504 /50x.html;
# location = /50x.html {
}Код: Выделить всё
server {
listen ***:80;
listen [***]:80;
server_name ***.com;
server {
listen ***:80;
listen [***]:80;
server_name www.***.com;
return 301 $scheme://***.com$request_uri;
}Код: Выделить всё
# For SSL Compatibility - WP Super Cache and WP Rocket depend on this
map $scheme $https_suffix { default ''; https '-https'; }
server {
listen ***:443 ssl http2;
listen [***]:443 ssl http2;
root /home/username/sites/***.com;
index index.php;
ssl_certificate /etc/certs/username/***.com_1578429318.crt_v2;
ssl_certificate_key /etc/certs/username/***.com_1578429318.key;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
ssl_ciphers TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES-128-GCM-SHA256:TLS13-AES-256-GCM-SHA384:ECDHE:!COMPLEMENTOFDEFAULT;
ssl_prefer_server_ciphers on;
add_header Strict-Transport-Security "max-age=31536000";
access_log off;
error_log /etc/nginx/vhost_logs/***.com_error;
pagespeed on;
pagespeed DisableFilters rewrite_images;
pagespeed FileCachePath /var/cache/ngx_pagespeed_cache;
pagespeed MemcachedServers "127.0.0.1:11211";
pagespeed XHeaderValue "Powered By ngx_pagespeed";
pagespeed BlockingRewriteKey "fullyoptimized";
pagespeed Disallow "*/wp-admin/*";
pagespeed Disallow "*/wp-login.php*";
set $skip_cache 0;
# POST requests and urls with a query string should always go to PHP
if ($request_method = POST) {
set $skip_cache 1;
if ($query_string != "") {
set $skip_cache 1;
if ( $cookie_woocommerce_items_in_cart = "1" ){
set $skip_cache 1;
# Don't cache URIs containing the following segments
if ($request_uri ~* "/wp-admin/|wp-.*.php|/feed/|index.php|sitemap(_index)?.xml") {
set $skip_cache 1;
if ($request_uri ~* "/(cart|checkout|my-account)/*$") {
set $skip_cache 1;
# Don't use the cache for logged-in users or recent commenters
if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_no_cache|wordpress_logged_in") {
set $skip_cache 1;
location / {
try_files $uri $uri/ /index.php$is_args$args;
location = /favicon.ico {
log_not_found off;
access_log off;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location ~ \.php$ {
#NOTE: You should have "cgi.fix_pathinfo = 0;" in php.ini
include fastcgi.conf;
fastcgi_intercept_errors on;
fastcgi_pass php-fpm;
fastcgi_cache microcache;
fastcgi_cache_key $scheme$host$request_uri$request_method;
fastcgi_cache_valid 60m;
fastcgi_cache_use_stale updating error timeout invalid_header http_500;
fastcgi_cache_bypass $skip_cache;
fastcgi_no_cache $skip_cache;
fastcgi_pass_header Set-Cookie;
fastcgi_pass_header Cookie;
fastcgi_ignore_headers Cache-Control Expires Set-Cookie;
add_header X-Cache $upstream_cache_status;
location ~* \.(js|css|png|jpg|jpeg|gif|ico)$ {
expires max;
log_not_found off;
include /home/username/sites/***.com/*.conf;
server {
}Тоже, что и все остальные. Например для brainycp.com это будет server1702.shneider-host.ru
