reverse proxy
rootx
reverse proxy
Сообщение rootx » Пн окт 07, 2019 8:26 am
Добрый день, подскажите возможно ли на некоторых доменах работа в качестве обратного прокси?
Ручное изменение конфигурации перезатерается после мягкой перезагрузки сервера.
rootx
Re: reverse proxy
Сообщение rootx » Пн окт 07, 2019 9:05 am
Индивидуальная донастройка хостов
        proxy_pass http://172.16.222.8:8085;
        proxy_set_header Host $host;
Active: failed (Result: exit-code) since Mon 2019-10-07 11:54:06 MSK; 15ms ago
Process: 31594 ExecStartPre=/usr/sbin/nginx -t (code=exited, status=1/FAILURE)
Process: 31593 ExecStartPre=/usr/bin/rm -f /run/nginx.pid (code=exited, status=0/SUCCESS)
Main PID: 27241 (code=exited, status=0/SUCCESS)
Oct 07 11:54:06 web1.k.ru nginx[31594]: nginx: [warn] the "ssl" directive is deprecated, use the "listen ... ssl" directive instead in /etc/nginx/sites-available/ssl.default.conf:7
Oct 07 11:54:06 web1.k.ru nginx[31594]: nginx: [warn] the "ssl" directive is deprecated, use the "listen ... ssl" directive instead in /etc/nginx/sites-available/ssl.k.ru.conf:7
Oct 07 11:54:06 web1.k.ru nginx[31594]: nginx: [warn] duplicate MIME type "text/html" in /etc/nginx/sites-available/ssl.k.ru.conf:40
Oct 07 11:54:06 web1.k.ru nginx[31594]: nginx: [warn] the "ssl" directive is deprecated, use the "listen ... ssl" directive instead in /etc/nginx/sites-available/ssl.rd.k3.ru.conf:7
Oct 07 11:54:06 web1.k.ru nginx[31594]: nginx: [emerg] invalid parameter "on" in /etc/nginx/sites-available/ssl.rd.k3.ru.conf:46
Oct 07 11:54:06 web1.k.ru nginx[31594]: nginx: configuration file /etc/nginx/nginx.conf test failed
Oct 07 11:54:06 web1.k.ru systemd[1]: nginx.service: control process exited, code=exited status=1
Oct 07 11:54:06 web1.k.ru systemd[1]: Failed to start The nginx HTTP and reverse proxy server.
Oct 07 11:54:06 web1.k.ru systemd[1]: Unit nginx.service entered failed state.
Oct 07 11:54:06 web1.k.ru systemd[1]: nginx.service failed./code]
rootx
Re: reverse proxy
Сообщение rootx » Пн окт 07, 2019 9:09 am
я так понимаю нужно поменять
ssl on;
на
 listen 443 ssl;
rootx
Re: reverse proxy
Сообщение rootx » Пн окт 07, 2019 9:28 am
При попытке сново добавить :
nginx: [emerg] "proxy_pass" directive is not allowed here in /etc/brainy/data/webserver_config/user_includes/proxy/rd.k3.ru.nginx.ssl:1
1 - listen 443 ssl; меняет обратно на ssl on;
Re: reverse proxy
Сообщение sbury » Пн окт 07, 2019 10:40 am
да на SSL он предупреждение выдает. А ругается он на эту строку
говорит что эта директива тут не может находится. Покажите основной конфиг, где этот инклуде включается
lacoste-sochi
Re: reverse proxy
Сообщение lacoste-sochi » Чт янв 02, 2020 7:43 pm
Та же беда (((
Хочу проксировать nuxtjs на локалхосту:3000 , в конфиге по пути /etc/nginx/sites-available уже есть директива proxy_pass (в ssl и простом файле)
Из-за этого не могу прописать в настройке доп вирт хоста. Если вписываю прокси в основной, каждую ночь слетает конфиг, перезатирается...
Updated
Переименовал папку => sites-available в sites-available(no_write)
Указал в nginx.conf => include /etc/nginx/sites-available(no_write)/*.conf;
Перестало слетать все )))
Lotus
Re: reverse proxy
Сообщение Lotus » Чт мар 05, 2020 9:38 pm
Не понял я этой махинации. Т.е. понял, но а что же с папкой sites_available и с новыми сайтами? Они же добавляться будут именно в эту папку...
Как-то не хочется так делать.
А у меня проблема та же. Есть сервер внутри сети, хочу спроксировать его через nginx.
На форуме совет прочитал:
прописать внутренний ip напрямую в конфиге в proxy_pass.
Вот тема: viewtopic.php?f=3&t=808
Все работает как нужно, только ночью возвращается назад!!
Админы, посоветуйте решение, пожалуйста.
Lotus
Re: reverse proxy
Сообщение Lotus » Сб мар 07, 2020 7:04 am
А я сделал так:
Добавил папку sites-available(no_write)
В нее поместил только тот конфиг, который не нужно перезаписывать ночью.
ПЕРЕД стандартной записью include /etc/nginx/sites-available/*.conf;
Прегрузил nginx.
Все заработало и слетать не будет.
Сначала загружается исправленный конфиг, а уже конфиг из sites-available не воспринимается.
ordex
Re: reverse proxy
Сообщение ordex » Сб мар 07, 2020 8:52 am
Фига вы накостылили, даже посильнее моего chattr +i на конфиг пока про vhosts.tpl не узнал.
Скопируйте /etc/brainy/conf/vhosts/vhosts.tpl в /etc/brainy/conf/vhosts/vhosts.local.tpl (чтобы не затирался при обновлении) и набросайте что вам нужно, можно использовать конструкцию
{if $domain == "your.domain.com"}
{else}
{/if}
Lotus
Re: reverse proxy
Сообщение Lotus » Сб мар 07, 2020 10:57 pm
А панель обновится вдруг с vhosts.tpl? Опять все послетает резко и по новой шаблон править?
