/etc/rd.d/rc.local +mysql
pomoyka
Сообщение pomoyka » Вт мар 07, 2023 9:57 pm
[[32m OK [0m] Started Crash recovery kernel arming.
[[0m[31m* [0m] (1 of 3) A start job is running for Clam Anti...s a TCP/IP or unix domain (14s / 1min 33s)
[K[[1;31m*[0m[31m* [0m] (1 of 3) A start job is running for Clam Anti...s a TCP/IP or unix domain (14s / 1min 33s)
[K[[31m*[1;31m*[0m[31m* [0m] (1 of 3) A start job is running for Clam Anti...s a TCP/IP or unix domain (15s / 1min 33s)
[K[ [31m*[1;31m*[0m[31m* [0m] (2 of 3) A start job is running for /etc/rc.d/rc.local Compatibility (15s / no limit)
[K[ [31m*[1;31m*[0m[31m* [0m] (2 of 3) A start job is running for /etc/rc.d/rc.local Compatibility (16s / no limit)
[K[ [31m*[1;31m*[0m[31m*[0m] (2 of 3) A start job is running for /etc/rc.d/rc.local Compatibility (16s / no limit)
[K[ [31m*[1;31m*[0m] (3 of 3) A start job is running for Clamd SMT...n MTA And Content Checkers (17s / 3min 3s)
[K[ [31m*[0m] (3 of 3) A start job is running for Clamd SMT...n MTA And Content Checkers (17s / 3min 3s)
[K[ [31m*[1;31m*[0m] (3 of 3) A start job is running for Clamd SMT...n MTA And Content Checkers (18s / 3min 3s)
[K[ [31m*[1;31m*[0m[31m*[0m] (1 of 3) A start job is running for Clam Anti...s a TCP/IP or unix domain (18s / 1min 33s)
[K[ [31m*[1;31m*[0m[31m* [0m] (1 of 3) A start job is running for Clam Anti...s a TCP/IP or unix domain (19s / 1min 33s)
[K[[1;31mFAILED[0m] Failed to start /etc/rc.d/rc.local Compatibility.
See 'systemctl status rc-local.service' for details.
Warning in ./libraries/classes/Dbi/DbiMysqli.php#231
mysqli_query(): (22003/1690): BIGINT UNSIGNED value is out of range in '(unix_timestamp() - 18446744073709540894)'
Backtrace
./libraries/classes/Dbi/DbiMysqli.php#231: mysqli_query(
string 'SELECT UNIX_TIMESTAMP() - 18446744073709540894',
integer 0,
./libraries/classes/DatabaseInterface.php#319: PhpMyAdmin\Dbi\DbiMysqli->realQuery(
integer 1,
./libraries/classes/DatabaseInterface.php#1631: PhpMyAdmin\DatabaseInterface->tryQuery(
integer 256,
integer 1,
boolean false,
./libraries/classes/Server/Status.php#62: PhpMyAdmin\DatabaseInterface->fetchValue(string 'SELECT UNIX_TIMESTAMP() - 18446744073709540894')
./libraries/classes/Server/Status.php#33: PhpMyAdmin\Server\Status::getHtmlForServerStateGeneralInfo()
./server_status.php#31: PhpMyAdmin\Server\Status::getHtml()
Этот сервер MySQL работает 2.135039823346E+14 дней, 3 часов, 58 минут и 56 секунд. Запущен Янв 01 1970 г., 03:00.
Как лечить эту беду? на втором сервере за 4дня вылезло....
rc-local.service - /etc/rc.d/rc.local Compatibility
Loaded: loaded (/usr/lib/systemd/system/rc-local.service; static; vendor preset: disabled)
Active: failed (Result: exit-code) since Ср 2023-03-08 00:47:32 +03; 8min ago
Process: 1162 ExecStart=/etc/rc.d/rc.local start (code=exited, status=1/FAILURE)
мар 08 00:47:32 rc.local[1162]: umount: /home/88/usr/share/zoneinfo: not mounted
мар 08 00:47:32 rc.local[1162]: umount: /home/88/usr/share/GeoIP: not mounted
мар 08 00:47:32 rc.local[1162]: umount: /home/88/usr/share/mc: not mounted
мар 08 00:47:32 rc.local[1162]: quotacheck: Cannot find filesystem to check or filesystem not mounted with quota option.
мар 08 00:47:32 systemd[1]: rc-local.service: control process exited, code=exited status=1
мар 08 00:47:32 systemd[1]: Failed to start /etc/rc.d/rc.local Compatibility.
мар 08 00:47:32 systemd[1]: Unit rc-local.service entered failed state.
мар 08 00:47:32 systemd[1]: rc-local.service failed.
Re: /etc/rd.d/rc.local +mysql
Сообщение alenka » Ср мар 08, 2023 9:13 am
Свяжитесь с нами через скайп.
