yum update: error summary (конфликт)
con
Сообщение con » Сб авг 22, 2020 7:13 am
Доброго времени.
С каких-то пор перестала обновляться панель. Судя по выводу в консоли, есть конфликты. Помогите пожалуйста решить проблему. Ниже часть лога, во вложении полный лог.
вывод uname -r
3.10.0-1127.el7.x86_64
Transaction Summary
Install   2 Packages (+28 Dependent packages)
Upgrade  79 Packages
Remove    1 Package
Total size: 120 M
Is this ok [y/d/N]: y
Downloading packages:
Running transaction check
Running transaction test
Transaction check error:
file /usr/bin/ab conflicts between attempted installs of httpd24-tools-2.4.46-2.el7.x86_64 and httpd-tools-30:2.2.34-20.el7.centos.x86_64
file /usr/bin/htdbm conflicts between attempted installs of httpd24-tools-2.4.46-2.el7.x86_64 and httpd-tools-30:2.2.34-20.el7.centos.x86_64
file /usr/bin/htdigest conflicts between attempted installs of httpd24-tools-2.4.46-2.el7.x86_64 and httpd-tools-30:2.2.34-20.el7.centos.x86_64
file /usr/bin/htpasswd conflicts between attempted installs of httpd24-tools-2.4.46-2.el7.x86_64 and httpd-tools-30:2.2.34-20.el7.centos.x86_64
file /usr/bin/logresolve conflicts between attempted installs of httpd24-tools-2.4.46-2.el7.x86_64 and httpd-tools-30:2.2.34-20.el7.centos.x86_64
file /usr/share/man/man1/htdbm.1.gz conflicts between attempted installs of httpd24-tools-2.4.46-2.el7.x86_64 and httpd-tools-30:2.2.34-20.el7.centos.x86_64
file /usr/share/man/man1/htdigest.1.gz conflicts between attempted installs of httpd24-tools-2.4.46-2.el7.x86_64 and httpd-tools-30:2.2.34-20.el7.centos.x86_64
file /usr/share/man/man1/htpasswd.1.gz conflicts between attempted installs of httpd24-tools-2.4.46-2.el7.x86_64 and httpd-tools-30:2.2.34-20.el7.centos.x86_64
file /usr/share/man/man1/httxt2dbm.1.gz conflicts between attempted installs of httpd24-tools-2.4.46-2.el7.x86_64 and httpd-tools-30:2.2.34-20.el7.centos.x86_64
yum update log.zip
(1.07 КБ) 1285 скачиваний
Centos7
Marfey
Re: yum update: error summary (конфликт)
Сообщение Marfey » Чт фев 25, 2021 6:06 am
Аналогичная проблема. Что делать?
con
Сообщение con » Чт фев 25, 2021 7:09 am
Переустановил панель вот по этому алгоритму
Centos7
Marfey
Сообщение Marfey » Чт фев 25, 2021 8:21 am
А если у меня там много сайтов сидит? их не поломает?
con
Сообщение con » Чт фев 25, 2021 8:51 am
Если вы удалите VPS и заново начнете ставить, то конечно все слетит. Если не знаете - то лучше делегируйте эту задачу тому, кто разбирается. Судя по вашим вопросам вы не особо разбираетесь.
Перед переустановкой нужно сделать полный бекап базы данных, файлов. У меня тоже с десяток сайтов висело. Ну и что делать, если такая беда?
Еще попробуйте написать в поддержку на оф сайте брейни. Обычно, там сразу помогают. Но если будет геммор или какая-то более сложная проблема больше чем на 5 минут, то придется вам решать самостоятельно (у меня лично всегда так было). Так что смотрите сами.
Centos7
Marfey
Сообщение Marfey » Чт фев 25, 2021 11:17 am
Все банально просто. Удалил лишние репозитории и все заработало. Оставил только базовый CentOS и Brainy.
con
Сообщение con » Чт фев 25, 2021 11:58 am
А у какого хостера VPS арендуете?
Centos7
Marfey
Сообщение Marfey » Чт фев 25, 2021 12:12 pm
Я не орендую. У меня свои серваки есть.
con
Сообщение con » Чт фев 25, 2021 12:55 pm
Интересно, а откуда могли взяться левые репозитории? У меня такое только когда ставлю у одного из хостеров.
Centos7
De_mon
Сообщение De_mon » Пт фев 26, 2021 12:40 pm
Скажу больше , была история на собственном сервере и Cent OS 8 , репозиторий вообще пропал, поддержка оперативно обнаружила и поправила.
